min height for chimney burning natural gas
U2WATCHER
U2WATCHER Member Posts: 9
DOES ANYBODY KNOW WHAT IS THE MIN. HEIGHT OF A CHIMNEY OF AN ATMOSPHERIC DRAFTED BOILER TO THE TOP OF THE CROWN OF THE CHIMNEY. I CAN NOT FIND IT IN THE NATIONAL FUEL GAS CODE BOOK.
  • Ron Schroeder
    Ron Schroeder Member Posts: 998
    I might not have this complete as
    it is off the top of my head but 2 feet higher than anypart of the stucture within 10 feet. so if you go up next to a roof you neeed toi be 2 feet higher than the highest side at ten feet away.
  • S Ebels
    S Ebels Member Posts: 2,322
    Hmmmm
    Are you trying to find out what the shortest allowable total height is?
  • U2WATCHER
    > away.
    I THINK ITS 3 FEET ABOVE ROOF AND 2 FEET ABOVE ANYTHING WITHIN 10 FEET
  • Joe Grosso
    Joe Grosso Member Posts: 307
    Height
    Also, the horizontal connector can't be more than I believe 2/3's of the height of the stack.
  • U2WATCHER
    I WAS ON A JOB TODAY AND B VENT ROTTED OUT.I LOOKED OUTSIDE AND BOILER INSTALLED REALLY IN CLOSET OUT SIDE OF HOUSE AND CHIMNEY IS GOING THOUGH ROOF ABOUT 4 1/2 FEET
  • S Ebels
    So the total height.......
    So the total height of the chimney is how many feet? To get a good answer you'll need to know the stack diameter and the BTU input of the boiler also.
  • hr
    hr Member Posts: 6,106
    Would it be
    the length needed to get the draft reading the manufacture requires?
    Did you check NFPA 54?
    hot rod
  • Vent has to be a minimum
    of 5 feet above the draft hood outlet. NFPA 54 National Fuel Gas Code(2006) section 12.6.2.3 page 54-97.
