Rust at draft hood
Josh_9
Member Posts: 5
Thanks for the help
Josh
Josh
I have to take a state hvac test tomorrow and was hopping that I could get some clarification on a few questions.
Q: What is the primary cause of rust at the draft hood?
A: to many 90s or a blocked chimney?
A: Back drafting is an answer that I also came up with but this I do not under stand isnt the draft hood supposed to prevent this?
Q: what is the acceptable temperature rise for gas or an oil furnace?
A: I came up with several different ones but am betting on 45-70 degrees is this correct?
Well thanks in advance I appreciate the help
I will say
A blocked chimney is primary cause of rust, and a 70 degree rise for a gas or oil furnace is ok. J.Lockard0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 64 Pipe Deterioration
- 917 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
