hepex or aquapex
Adam_12
Member Posts: 39
Doing some work in a Lab today and noticed that the radiant cooling panels had aquapex running to them .I know that higher tempuratures increase the amount of oxygen the non barrier pipe will absorb,the water is at about 50 degrees .The circulators are not bronze or stainless steel could this cause problems in the near future?.
Depends
It really depends on the amount on non-barier tubing vs the amount of ferris metel. 50 degree water is very cool and will slow the process down considerably.
Tim D.0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 916 Plumbing
- 6K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
