Convert Baseboard to In-Floor Radiant Heat
Al Letellier
Member Posts: 781
Yes you can, but how depends on what kind of system you have and if you want a separate zone in the bath. you will have to install a mixing valve to lower the temperature as radiant uses a lot lower temp than the baseboard. Past experience has taught us that bathroom floors get cold when the thermostat is in another room. Consider putting it on a separate zoneif possible. A little more costly to install but a much happier bathroom!!!!
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=248&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
I currently have baseboard hot water heat in a small bathroom, and I am about to renovate the bathroom. Can I use the existing baseboard hot water supply and return connections for under floor radiant heat once I remove the floors?0 -
Floor stat
Like Al said but use a floor thermostat not a wall one. The floor will be warmer than the air and not get a false reading.0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 916 Plumbing
- 6K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
