CONTRACTORS
CHAD_3
CHAD_3 Member Posts: 1
Hello,
I just moved into a house with radiators and know nothing about them. I am looking for a contractor in my area to come over and do a check on them and give me some advice on maintenance, etc. We live near Rochester Minnesota.
Thanks,
Chad
  • Dale
    Dale Member Posts: 1,317
    Q&A
    You may want to check the q and a to the left. That way you'll learn a bit, like hot water or steam heat so you can communicate with the contractor. If you go to "find a professional" and put in your zip code you should get a good start to find someone you can trust. If you have a steam system take plenty of time to learn what you have before getting someone in.
