oil pump
jaybee
jaybee Member Posts: 128
I was priming a pump toady after tune-up and it made a squilling noise before it picked up oil why does a pump make that kind of noise?
  • gregsr74
    gregsr74 Member Posts: 2
    PULLING HI VAC.
  • Ken D.
    Ken D. Member Posts: 836
    Pump
    Probably because the pump is empty of oil and therefore has little lubrication. When it picks up the oil it quiets down due to the lubricating effect of the oil. Sounds good to me.
  • Weezbo
    Weezbo Member Posts: 6,232
    put a tiger loop combo on it .and it will quit....
  • Firedragon_4
    Firedragon_4 Member Posts: 1,436
    It's perfectly normal for a pump
    to do that while open and under vacuum, don't do anything, forgitaboutit!
