indirect heaters
Matt_21
Matt_21 Member Posts: 140
i have a particular job where i only have 3' of height to install a boiler and indirect heater. i haven't done a load calc yet but the boiler will probably only be 100,000 - 120,000 btu. does anyone know a manu. who has a boiler and horizontal indirect to fit in this space.
  • Ranger
    Ranger Member Posts: 210
    How much?
    ...room do you have side 2 side? Crown (and I'm sure other
    manufactures do also,I had a convertable upright or horz.Triangle Tube in my last house) makes a Model MSH-40H
    that is approx. 24" tall 24" deep and 35" long. with mabie a
    NTI Trinity or a Munchkin hung next to it?I don't know how much fun installation or serviceing would be though...
  • Ranger
    ...and be kind
    ...to the next guy when planing the install.My buddy King James had to fight with a Teladyne-Laars this past saturday (Indirect on the bottem,boiler on top)Pinched in a closet w/the burner access faceing the wrong way.Had to transform into Gumby to work on the darn thing...
  • DaveGateway
    DaveGateway Member Posts: 568
    If you only have 3ft clearance
    you can't stack boiler and indirect. Crown has the H40 and I think a 50gal horizontal was also comming out. Viessmann also has a SS horizontal. Buderus has horizonal tanks. (not SS). A few makers have smaller low boy model vertical tanks under 3ft like Peerless's 30 gal.
    There's a bunch of gas boilers that would fit, oil might limit you to 3-pass horizonal vent models like Crown Freeport, Biasi, Buderus and Viessmann.
  • Matt_21
    side to side
    i have plenty of room. this is a platform in the basement. it 's only purpose is to keep the equipment out of the water if there is a flood. i can make it as wide as i want it is only the 3' high that is the problem.
  • ScottMP
    ScottMP Member Posts: 5,884
    Matt
    Look into Buderus indirects, they make a very good horizontal unit.
    We have used them quite alot with no call backs to date.
    Scott
