Humidification with steam heat system?
Andrew Staricco
Member Posts: 1
I have a 1927 one-line steam heat system. Boiler about 15 years old. Works great, but I am concerned about humidity in the house. Do steam heat system release any or enough steam to adequately humidify a home? Can different valves be used to enhance humidity, or should a separate system be used?
The heating system
has nothing to do with how dry or humid a house is.
Humidity levels are directly connected to air leakage.
If your home is too dry, you have too much air leakage.
Try to find someone to perform a blower door test on your home.
Mark H
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Contractor"0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 916 Plumbing
- 6K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
