Storage
guys use to store fittings and all the stuff you need in your trucks for installs? I just upsized from my astro van to a savana cut away(a huge step for me) and have the dilemma of finding a bin system....the akro-mills stuff look ok but pricey new...used is hard to find. Any pictures of finished products you care to share? please. kpc
  • paul lessard_2
    paul lessard_2 Member Posts: 192
    Hey kevin
    Is it a normal box? or do you have doors on the outside too?
  • kevin coppinger_4
    kevin coppinger_4 Member Posts: 2,124
    I have the utility...
    doors on the outside too.kpc
  • paul lessard_2
    Ok I'll get the boots and camera
  • paul lessard_2
    I hope this can help
    the plastic boxes are from a place called american van(rude bunch of people!) the rest was done with a table saw...
    lots of room
  • jim lockard
    jim lockard Member Posts: 1,059
    W.W Graingers
    Has some nice boxs that have dividers in them so that I use to seprate my small copper and black fittings. They fit on the shelves real nice and tight. The other containers I use are the 10 gallon rubber maid box with lid as I can stack them 2 high under my shelves and carry the stuff I need but do not use every day. Since I live somewhat rual Kevin I need to carry alot of product and I need to be able to find the product when I get to the battlefield.
    I have a 10 ft box truck that for the most part works well for my use. Best Wishes J.Lockard
  • ScottMP
    ScottMP Member Posts: 5,883
    Paul
    Really nice work. The shelving system you've made is really sweet, I can see alot of work went into it.
    We also use American Van and have not found them to be so rude. I will say our last order was screwed up and took a while to get. Normally they ship stuff out pretty quickly.
    Here's their web address, its a good place to start.
    www.americanvan.com
    Scott
    To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Contractor"
  • clammy
    clammy Member Posts: 3,163
    fitting storage
    i
    ,ve also always had promblems with fitting storage nothing is worse then no organation but what i've found that works the best is the old 1 quart glass soda cases there about 5 inches high with about 12 bins they used to be used by a place called brookdale soda i copped myself about 6 or 7 of them years ago and still use them i had stumbled across them at a beer making supply house they where extremlly cheap i have been looking for more but haven't found them yet each bin is stackable and fit alot of stuff between 5 of them ican fit electric, copper 1/2 to 1 1/4 steel up to 1 inch ,a bin of assorted clamps clevis hyasborb and the likes and then all speciality stuff i wish someone would still make them a few plumbers i know use them and say without them they would be screwed good lucy there dimension are like16 x 20 peace
    R.A. Calmbacher L.L.C. HVAC
    NJ Master HVAC Lic.
    Mahwah, NJ
  • kevin coppinger_4
    thanks!
    just what I was looking for...I have been working out of a mess for a couple of years now....I knew where everything was but now have someone working for me...he can't find anything amidst the clutter. I have some pictures when I get the new rig lettered up.kpc
  • hr
    hr Member Posts: 6,106
    Buckets, baby
    I love them. Get a couple "bucket seats" for them for those extended troubleshooting jobs.
    The bucket can come in handy should a leak spring up unexpectedly!
    I built under body boxes to hold a total of 8 buckets. Pex copper and black threaded fittings.
    I also keep my transfer pump and an assortment of washer hoses in one. It allows you to blend and pump glycol and chemical treatments .
    www.duluthtrading.com is a good source.
    hot rod
  • Jeff Lawrence_21
    Jeff Lawrence_21 Member Posts: 8
    Buckets
    I went to Lowes and they had the bucket stackers like HR shows in his pictures.
    I found a couple of 6 gallon buckets and have stackers for both of them, one for copper fittings and the other for PEX fittings. Easy to inventory what I have and easy to see what I need.
    In fact, I got the idea FROM Hot Rod.
    J.
