yello jacket oil prss. test kit
john luebbers
Member Posts: 8
I have a chance to buy the yellow jacket pump press. test kit, is there a better set up or is this pretty much it?
Yellow
Mine is pushing 20 and still works good. you will need a few more adapter kits than it comes with.0 -
Check out Westwood Products
They have a few different testers, including an inline pump pressure testerthat temp. replaces the nozzle line and allows you to do a cutoff test, an inline vacuum tester that can be installed betweena ny 3/8th's or 1/2" suction line, and there are the Vac-Bolt testers that can be installed in place of the filter bolt for vacuum checks. They also have a manifold tester designed for Riello burners if you work on them. You can check them out at http://www.westwoodproducts.com/product_group_T.htm Also, Sid Harvey's carry similar testers, but the Westwood gauges are all Glycerin filled and I believe the Sid's are regular gauges.
Oh, I don't have one of the Y.J. kits, but if it's like my other Y.J. tools, you can't go wrong.0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 916 Plumbing
- 6K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
