Need a helping hand - David Broome
Ran into a bit of a problem today, got turned down today on a rough in inspection. Yes I got turned down. We hung a airhandler under a house. Used all the right things, all tread, i bolts, treated lumber. New builing inspector says the unit has to be at least six inches from the ground. I said show it to me, he said he would tomorrow. Did I miss something in the international code changes this year, I can't find it any where. I don't want to pin this guy ears to the wall and he pull out some revision that is so small it would take a telescope to read.
David C. Broome
Waiting with one 24" and one 36" pipe wrench :)
David C. Broome
New one on me.
But I have never run into a situation where I was that close.
Worst case, dig a hole under it!!!!
Good luck.
Mark H
Int'l Mech Code
I'm looking at the '96 edition, 304.7. A bit of humility may be in order if using the Mechanical code on this job. Maybe the official will allow a condenser pad or two between the bottom of the equipment and Mother Earth. I learned the hard way here that some officials use CABO for residential. Every code but CABO requires gas shut-offs to be not more than 6 feet from the equipment. CABO requires 4 feet max. (sometimes difficult on a log job)In addition to moving the valve, I nearly had to buy his lunch, too. He almost lured me into a wager. That's something else I learned that day...Never bet an inspector concerning codes.
Good Luck
Larry0 -
Be Careful
and don't get him mad at you.
Bill Russell0
- 86K THE MAIN WALL
- 52 Biomass
- 421 Carbon Monoxide Awareness
- 80 Chimneys & Flues
- 5.3K Gas Heating
- 96 Geothermal
- 154 Indoor-Air Quality
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 892 Plumbing
- 5.9K Radiant Heating
- 378 Solar
- 14.7K Strictly Steam
- 52 Water Quality
- 41 Industry Classes
