mixing valve domestic hot water advice
Have an oil fired hot water heater, I did not find a stat on the tank, and when I use a thermometer at the kitchen sink on full hot I see 140 °F.
I am ok with leaving the hot water tank as is; I have a 1/2" port size Calef. mixing valve (with gauge) on the way. Are there any do's, don'ts, best practices for installing?
Unfinished basement, 40' x 20' single level ranch, 1.5 bath and only 1 shower that would be used by one person. Piping leaving hot water tank is 3/4" and run's alongside cold water pipe length of basement, for about 10' before reducing to 1/2" copper pipe that then runs to each bathroom and kitchen.
I am planning on putting the mixing valve just before where the 1/2" hot water pipe tee's to go to the main bath with shower. And from that point on the existing 1/2" copper pipe everything else is downstream from that. And was planning on teeing before the mixing valve so washing machine gets hot hot water and not ~110°F hot, is this a good idea or should everything get mixing valve hot water including the washing machine? And kitchen dishwasher also would be fed before the mixing valve and would get 140°F.
thanks.
thanks.
Sounds fine to me, as long as you're comfortable with a little extra premature wear on your clothes from the extra water temp0
ASHRAE recommends 140* water minimum to control legionnaires disease. After that 120 max at point of use.No need for very hot water at the washing machine. Your just wasting $’s.0
- 117.5K All Categories
- 82.8K THE MAIN WALL
- 2.7K A-C, Heat Pumps & Refrigeration
- 43 Biomass
- 402 Carbon Monoxide Awareness
- 8 Chimneys & Flues
- 1.6K Domestic Hot Water
- 4.3K Gas Heating
- 107 Geothermal
- 148 Indoor-Air Quality
- 2.7K Oil Heating
- 45 Pipe Deterioration
- 679 Plumbing
- 4.8K Radiant Heating
- 353 Solar
- 13.3K Strictly Steam
- 2.9K Thermostats and Controls
- 48 Water Quality
- 31 Industry Classes
- 65 Job Opportunities
- 11 Recall Announcements
