Need circulator advice
bigdee4444
Member Posts: 12
I’m will be replacing my boiler and fresh components. I’m trying to get high efficient circulators with ifc’s so I can eliminate the flow control valves. I plan on going with taco e series. One I’m confused about is the indirect to the boiler. There is currently a taco 007f4 a cartridge circulator. Can I replace that with a taco 007e ?
Yes.0
The pump curves are nearly identical, so yes. The 007e can replace the 007f40
That’s awesome thanks so much.0
- 120.3K All Categories
- 83.6K THE MAIN WALL
- 2.8K A-C, Heat Pumps & Refrigeration
- 52 Biomass
- 414 Carbon Monoxide Awareness
- 30 Chimneys & Flues
- 1.7K Domestic Hot Water
- 4.6K Gas Heating
- 114 Geothermal
- 152 Indoor-Air Quality
- 2.9K Oil Heating
- 49 Pipe Deterioration
- 736 Plumbing
- 5.2K Radiant Heating
- 357 Solar
- 13.8K Strictly Steam
- 3K Thermostats and Controls
- 50 Water Quality
- 36 Industry Classes
- 70 Job Opportunities
- 14 Recall Announcements
