redline water wetter in hydronic system ?
ron
Member Posts: 301
https://redlineoil.com/Content/files/tech/WaterWetter%20Tech%20Info.pdf
why would using a surfactant like this in a hydronic system having an oil fired cast iron boiler be a bad idea?
Red Line WaterWetter®is designed to provide improved metal wetting and excellent corrosion inhibition when added to plain water
• Doubles the wetting ability of water
• Improves heat transfer
• Reduces rust, corrosion and electrolysis
• Provides long term corrosion protection
- 120.1K All Categories
- 83.6K THE MAIN WALL
- 2.8K A-C, Heat Pumps & Refrigeration
- 52 Biomass
- 414 Carbon Monoxide Awareness
- 29 Chimneys & Flues
- 1.7K Domestic Hot Water
- 4.6K Gas Heating
- 114 Geothermal
- 151 Indoor-Air Quality
- 2.9K Oil Heating
- 49 Pipe Deterioration
- 735 Plumbing
- 5.2K Radiant Heating
- 355 Solar
- 13.8K Strictly Steam
- 3K Thermostats and Controls
- 50 Water Quality
- 36 Industry Classes
- 69 Job Opportunities
- 14 Recall Announcements
