humor me - hydronic w/oil boiler piping
ron
Member Posts: 301
got a new wgo3 installed few years ago, was interested in understanding everything and sorta did, forgot about it, need to replace a couple 20 year valves on zone return side and interested again in the whole setup...
is there a single answer that is the most ideal piping for
is there any kind of building code or best practice or bad practice when circulator pumps and other hydronic related equipment are mounted to the wall behind a boiler where the boiler is typically positioned about a foot out from that wall?
- an oil fired water boiler that does NOT have a tankless coil
- supplying 2 heat zones (the first floor above and the second floor above in a 2 story house)
- baseboard radiator heating
- and accommodating a 45 gal indirect water heater for domestic hot water
Didn't you offer to design a hydronic system for someone?
https://forum.heatinghelp.com/discussion/170865/is-there-someone-i-can-hire-to-design-my-panel-radiator-fin-tube-design#lateststeve0 -
touche
although it only said that for like 5 minutes0
- 120.1K All Categories
- 83.6K THE MAIN WALL
- 2.8K A-C, Heat Pumps & Refrigeration
- 52 Biomass
- 414 Carbon Monoxide Awareness
- 29 Chimneys & Flues
- 1.7K Domestic Hot Water
- 4.6K Gas Heating
- 114 Geothermal
- 151 Indoor-Air Quality
- 2.9K Oil Heating
- 49 Pipe Deterioration
- 734 Plumbing
- 5.2K Radiant Heating
- 355 Solar
- 13.8K Strictly Steam
- 3K Thermostats and Controls
- 50 Water Quality
- 36 Industry Classes
- 69 Job Opportunities
- 14 Recall Announcements
