will this hydronic circuit work?
ron
Member Posts: 301
my current install was done with circulators in the cold input side of boiler and they pump into the expansion tank (which is located where the 4900 air separator is in pic below). I need to replace some valves and was wondering if I move things around according to this pic below (moving circulators after the air separator and pumping away from the expansion tank, and maybe put zone valves on supply side?) will it all work [better?] ?
yes, try not to pipe the circulatory off a tee like that, if the both could run at the same time It’s called bull heading Use a tee and ellBob "hot rod" Rohr
Living the hydronic dream0 -
can you draw or link a pic showing what you mean by using a tee and ell?
the hydrostat on the boiler is supposed to de-energize the viridian circulator when the indirect calls for heat.0 -
also would like some clarification on bullheading . Does it simply mean to cause or induce a [reverse] flow that is undesirable?
If so, i'm curious if my current setup has the same possibility although I am pretty sure both circulators will not run at the same time. here is pic of existing setup
is this what you mean be tee and L ?
yep, do the same at the boiler returnBob "hot rod" Rohr
Hmmm. Are we pumping into the boiler? Is that high efficiency unit or a standard cast iron boiler?Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Consulting
Plumbing in NYC or in NJ.
Take his class.0 -
Be sure the circs have check valves."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0
- 120.1K All Categories
- 83.6K THE MAIN WALL
- 2.8K A-C, Heat Pumps & Refrigeration
- 52 Biomass
- 414 Carbon Monoxide Awareness
- 29 Chimneys & Flues
- 1.7K Domestic Hot Water
- 4.6K Gas Heating
- 114 Geothermal
- 151 Indoor-Air Quality
- 2.9K Oil Heating
- 49 Pipe Deterioration
- 735 Plumbing
- 5.2K Radiant Heating
- 355 Solar
- 13.8K Strictly Steam
- 3K Thermostats and Controls
- 50 Water Quality
- 36 Industry Classes
- 69 Job Opportunities
- 14 Recall Announcements
