If you've found help here, check back in to let us know how everything worked out.
It's a great way to thank those who helped you.
adding additive to hydronic system?
I have to replace some shutoff valves so I will be draining the system. I am interested in using a corrosion inhibitor additive. How does one add something like that to a hydronic system? And what's a good one that I should use?
setup: WM WGO-3 oil boiler with WM indirect tank, one circulator doing 2 zones having taco zone valves, and a 2nd circulator for the loop between the indirect and the boiler.
0 ·
I might re-relocate my expansion tank in addition to replacing zone valves and shut off valves on the return side prior to boiler. looking for piping ideas to make adding any cleaner/additive to the system easy
