Old Bryant boiler replacement piping
StephenQuattrucci
Member Posts: 11
looking to find out what the device on this steam system is and how I should pipe it back Ito a new boiler.
It's probably a reservoir tank, but it's mounted too high to do its job.
Its horizontal midpoint needs to be on the same height as the boiler water-level.--NBC0 -
I guess that's from pre Hartford Loop days.
That's a side shot domestic coil no?0 -
I found in Dan's companion to "Lost Art of Steam Heating" a section on Direct Return Steam traps. Finally here on the day of reckoning, 3 days before Thanksgiving installing new boiler! Do I pipe the new boiler in with equalizer and Hartford loop? There is none of that on this boiler now. Everything about the near boiler piping looks wrong. looking for "Dead Men" Advice0
yes to equalizer and Hartford loop. Follow the piping diagram in the boiler manual0
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
