Transport pipe making noices
Bosco
Member Posts: 30
Why does the transport pipe making water flow noices? Each time the time is turn on
Sounds like a low flow condition. How many pumps are on your system? Got pictures?
MEIt's not so much a case of "You got what you paid for", as it is a matter of "You DIDN'T get what you DIDN'T pay for, and you're NOT going to get what you thought you were in the way of comfort". Borrowed from Heatboy.2 -
Could be the boiler is over sized for the loads(s) is it a zoned system? What type of heat emitters. how about a load calculation for the building.
Copper tube boilers are a fairly low mass, low water content boiler. Without a consistent load they were prone to short cycling.Bob "hot rod" Rohr
Living the hydronic dream1 -
As mentioned above you boiler needs constant full flow when it is firing. Sounds like a flow restriction or a pump is not working0
I have the same problem with my epb 110. It started to give short term hot water and worsened to only 10 second intervals before cold water ran. I am looking for apost that may offer similar assistance.0
@tommyboy5740
It is probably better to start another post with all the details of your problem including pictures."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
Could be flow issue. Is this a new development, or something you just took notice of?
Seems some flow is occurring to drop 30 degrees in 1:30 min.
Is it warmer outside now?0 -
They are suppose to be piped primary/secondary. I've yet to see one piped that way.Steve Minnich0
Or, at least, with a bypass.Steve Minnich0
If I'm not mistaken... That Laars is a copper finned boiler. Similar to a Lochinvar. You definitely have a flow issue. I've seen it many times before. These boilers have a very small volume. If you don't have constant flow through the boiler it will over heat in less than a minute. It might make some pretty weird sounds as the water boils inside the boiler. I would say your flow restriction is either from a failed pump or air lock. My money would be on a bad pump. You need a technician.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
