Three boilers, what to do?
kami4444
Member Posts: 33
I have three boilers I am given.
1. A bladder boiler's air side is water logged, what to do?
2. A compression boiler air side is water logged what to do?
3. A diaphragm boiler is water logged what to do?
For 1, 2, and 3 what would you associate A, B, C with?
A) Replace the tank
Bleed the air from the tank
C) Bleed water from the tank
D) Drain water from the tank
Doing an assignment, all help is appreciated!
bladder boiler 1)
compression tank 2)
diaphragm tank 3)
A) Replace the tank
bladder boiler 1)
compression tank 2)
diaphragm tank 3)
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
