pipe sleeves
jonny88
jonny88 Member Posts: 1,139
I always sleeved my pipe with steel pipe when going through weight bearing walls etc and this is how i was taught,2 pipe sizes larger.That was in nyc. Now working on long island and all I see is pvc sleeves .which practice is right?
  • EzzyT
    EzzyT Member Posts: 1,378
    Both
    Both practices are right depending on where your working and unless the the manufacturer of the pipe states that it has to be sleeved in a certain way.
    E-Travis Mechanical LLC
    Etravismechanical@gmail.com
    201-887-8856
  • gerralstufler
    gerralstufler Member Posts: 5
    Correct
    I think the first practice is the correct one. It is more safe and durable than the pvc sleeves.
