Look what the "professional " did
nolamike
Member Posts: 9
I got pulled off the job to let the "pro"
To do the job . This is what he did. So how much of an issue do you think this is?
Seems to me the water hammer will be pretty bad. System operates at 10 psi has a 10' lift after . Was going to add an f&t trap and lift pump before this happened but now doesn't seem possible . What you all think?
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
