5" main
Gary_17
Member Posts: 37
Splitting 1 boiler into 2. Boilers only require 3" header. Will that work with the 5" mains or do we need to build 2 5" headers? Trying to avoid welding.
The boiler headers can be 3-inch
but the outputs from the boiler headers should go into a larger drop header. Dan has a diagram of this on page 67 of Lost Art.All Steamed Up, Inc.
Consulting0 -
Welded headers effect on boilers
Best to use threaded steel, as there is a little play in the joints for expansion and contraction, which could put undue stress on the sections, and their gaskets.
There is the same problem with copper headers.
Using a drop header makes it easier to fit, and avoid expansion problems.--NBC0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 916 Plumbing
- 6K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
