Lochinvar Knight Boiler "Lockout Fan Speed"
DSMComfort
Member Posts: 3
Got a knight we can't figure out. We have replaced the board and inducer. Cut apart our short 3" venting and found no blockage. Lockout still persists. Anyone ran into this problem?
Power
Make sure you have a good proper ground and a dedicated power line from the breaker panel.
If you have replaced the inducer blower and the controller it just might be a power problem.0 -
Re: lockouts
Sounds like to me you have a problem possibly with a harness if what you replaced is correct, have you talked to Lochinvar Tech, John the tech mgr is quite good if basic tech support can't help. Good luck.0 -
Lockout on fan speed
Just curious - what was the solution to this problem?0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
