12mm tubing & fittings
Streboa
Member Posts: 1
Looking for some help in locating 12mm. tubing and fittings to make repairs on system installed around 1985 north of Boston. House has radiant base board panels. Design is by Stadler and was relatively new at the time of install. Fittings are a type of stainless steel compression that thread directly into panel ends.
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
