\"Can't I just get him back...............hb
Rocky_3
Rocky_3 Member Posts: 236
C'mon! I spent alot of time putting that "system" together!
Rocky
  • heatboy_2
    heatboy_2 Member Posts: 48
    to fix it?\"
    Went to look at a "system" that doesn't work as promised (picture below). I informed him I would start over and rebuild his mechanical room properly . Naturally, he was stunned at the cost and wants the original guy to come back and fix this. Why would someone think the contractor who did this for pay to come back and redo it for free?
  • Phil_17
    Phil_17 Member Posts: 178
    wow what a mess
  • GLENN_14
    GLENN_14 Member Posts: 58
    I AGREE
    How did this guy get in the door.... I bet he was the low bidder :-)
  • ScottMP
    ScottMP Member Posts: 5,883
    Jeff
    I am not a fan of set point controls.
    Outside of that what is not working as promised ?
    I've (and you) have seen much worse
    Scott
  • Anna Conda
    Anna Conda Member Posts: 121
    Even better, why does he think the guy will redo it at all? Not without one heck of a fight. If the guy understood that his installation was wrong, he wouldn't have done it that way in the first place. They tend not to like being re-educated, particularly by homeowners.
  • Derheatmeister
    Derheatmeister Member Posts: 1,579
    Heatboy.Do not worry, it happens all of the time.I've had one that used all Aquapex in a plateless Stapleup in conj.of a Cast iron Boiler running it a 180F,When the Bioler was clogging up and blowing the reliefv. They keep on calling the Original Guy back.which would Purge the system.When we came on a emergency call because they could not get the Orig. installer,And we told them that it was a Total redo and it would cost X $. they called the Orig. Installer back and got a Quote from him to change the System as well! Which was approx $6000 less than ours.But the Dumba.. was going to Copy ours and did not really Know how to ,he was quoting for a indr.Waterheater that has a Ferr.Exchanger in conjunction with SS and Bronze, Which would have been another Disaster a couple years from now!... SO what i said is: You can give all the ingresses to a cook, that still does not mean that he is going to make a good meal.and explained what was going to happen! and i got the job.even thought i was justifiable higher in price! Sometimes there is a happy outcome....Keep on! you'll see! Richard from Heatmeister HM.
  • SpeyFitter
    SpeyFitter Member Posts: 422
    > free?
    The homeowner paid the contractor to perform a service (install a working heating system). The contractor did not perform the service yet, so the homeowner expects the contractor to perform the service in the future. If the contractor refuses to perform the service, the homeowner should take him to small claims court.
    I'm assuming the contractor hasn't lived up to his side of the contract with the homeowner.
  • educate me?
    it isn't the neatest, but what's causing it to not be working as promised?
