Cooper vs steel for manifold and near boiler pipings
jeff_73
Member Posts: 3
Had a peerless oil boiler for steam installed two years ago. They put Copper piping in from boiler for manifold and to the main steam line. I've since been told that cast iron/steel are better. I am having a lot a trouble with water hammer banging in the system, but I believe its farther down the main which is the problem. comments
j
j
Cooper vs Cast iron/steel for manifold
Had a peerless oil boiler for steam installed two years ago. They put Cooper piping in from boiler for manifold and to the main steam vent. I've since been told that cast iron/steel are better. I am having a lot a trouble with water hammer banging in the system, but I believe its farther down the main which is the problem. comments
j0 -
diagnosis
although copper for steam is hated and for good reason, if installed correctly it COULD work somewhat . any pipe, steel or copper if piped wrong will cause major problems. now we need the photos.0 -
I'll take some and post when available0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 916 Plumbing
- 6K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
