Cleaning/clearing a dry return
jeff_72
Member Posts: 7
Is it possible/typical to clean or clear a dry return (main)
on a one pipe steam system? There are two mains on my
system...both well insulated and vented. One ALWAYS gets
steam much faster then the other. The one that is slow to
get steam is vented with two Gorton #2s. With all that venting it seems it would clear the air in not time. There are no appearant places where there is any sagging where condensate could collect.
I'm wondering if there is some old crud that is blocking the line. I just had the boiler replaced a couple of weeks ago and perhaps it's new faster steam stirred up some old sediment. The boiler has been skimmed three times since its installation.
I'm stumpped! Any thoughts would be appreciated.
WE had one real bad[dirty} dry return ang added a draw off on one end and flushed it0 -
I shsould also say...
That if I shut off one of the radiators closer to the boiler, then the steam will move more quickly to shut
off the Gortons...but still the Hoffman side gets steam more
quickly.???0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 917 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
