crawlspace insulation
sws2_2
Member Posts: 14
I have radiant above an unheated crawlspace. Floor is pergo, quiktrac,T&G subfloor with r-19 fibreglass. On a cold day, (0 degrees)Areas where there is no tubing the floor is very cold, in particular around the perimeter. I would like to have the rim joist area and the foundation walls sprayed with a sealing foam. Anyone ever do that?? I could pull down the insulation, cut foam blocks, spray can foam but tht would be very labor intensive.Any other suggestions?? Approx. prices?? I am sure i'm losing a lot of heta downward. Cral is about 45", with about half below grade. Thanks.
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 916 Plumbing
- 6K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
