Paging Joe @ Buderus (Glenn H.)
Joe@buderus_2
Member Posts: 302
Glenn, we have tried the re-programming of the KIM module a couple of times and it did not resolve the issue. I was inquiring about the RC10 and found out it is sourced from Germany and it is possible there is a high limit of 167 degrees programmed in it. I hope to have more information about the RC10 soon. I will contact Mike Dorr on Monday. Thanks
Hi Joe
Noticed you were on this morning. Just trying to see if you received the last couple of e-mails I sent you this week regarding my problem GB142-30.0 -
Hi Glenn
I have received your e-mails and wish I could offer you a solution for the GB142 issue. It appears you have one of the applications where the GB142 appears to be only running on low fire. I will give you a call on Monday. Thanks,0 -
Maybe you didn't get all of them?
I did get your e-mail about the KIM module. I talked to our area rep. Mike Dore, who would appreicate you getting him a part number for the KIM for a GB142-45, along with a returned parts authorization so that I can get this unit reprogrammed and hopefully get rid of the 167º lockout with the RC10.
If you could Monday can you give Mike Dore a call at the number I provided in my last e-mail.
Thanks Joe.0 -
Thank you Joe,
That's what I needed to know.0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 917 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
