Small one-pipe steam radiator?
CHARLES_4
Member Posts: 61
Check out the Governale Co. in Brooklyn, N.Y. They sell a Burnham-style cast iron bbd which measures 2 5/8" thick X 10" tall. Provides appr. 750 Btu/sq ft @ 500lb/hr steam. Sometimes bathrooms won't give enough lineal footage to get the job done.
A few people have mentioned to me that I can replace my one-pipe steam bathroom radiator with a modern low-profile (baseboard-type?) radiator that is maybe only 1-2 feet high. I have searched the internet, and can't find anything like this. Does anyone know if this exists, and if so, where to find it?0 -
Beware
I've bought dozens of Governale radiators.
They are made in China and nearly evey one has a problem which requires attention before they are installed. Always pressure test them for leaks and make certain they are not filled with casting sand before you pipe them.
Once you check them out and fix them, they're fine.
Long Beach Ed0 -
thanks for the name of the place and to Ed for the warning - i'll check it out.0 -
Thanks for the advice,and to Ed for the warning- i'll check it out.0
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 113 Geothermal
- 164 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 49 Job Opportunities
