Banging Pipes in Steam system
Brook
Brook Member Posts: 1
Replaced original boiler (oil) in a 1925 home and switched to gas boiler. Original boiler had minimal or no noise. New 'energy efficient' gas boiler system is producing a lot of very loud water hammering in specific areas. What happened in the transition to cause this?
  • Christian Egli_2
    Christian Egli_2 Member Posts: 812
    Ferret out the steam
    Either poor near boiler piping allowing wet steam to leave the boiler room or the boiler water level altitude was lowered, thus uncovering previously wet returns to inquisitive steam.
    Those are the two first things that popped to my mind
  • GUS_2
    GUS_2 Member Posts: 2
    steam air valve
    noise of Steam coming from radiator was very loud so I changed the valve and is now worse and also the valve will not close will remain open during the time that the heat is on
    what can I do to fix this noise problem..specially at night
    when we sleep
  • Steamhead (in transit)
    Steamhead (in transit) Member Posts: 6,688
    Guys, I think
    it's time to call in a pro. Try the Find a Professional page of this site- it has plenty of good steam men on it.
    If either of you is in the Baltimore area, contact me.
