Ultra 155 Help!!!!
Sam_11
Sam_11 Member Posts: 19
Does anyone have any more ideas on delta t problem I have with the Ultra???? Please refer to the ultra post below.
thanks
  • Tony_23
    Tony_23 Member Posts: 1,033
    Patience
    > thanks
  • Tony_23
    Patience...
    I think you're being nervous :)
  • Brian (Tankless)
    Brian (Tankless) Member Posts: 340
    Accuracy could be improved
    if you wrap insulation around the strap-on sensors. I've come across this before, when monitoring refrigeration efficiencies. They're being confused by trying to read pipe temps and affected by ambient air at the same time.
    Your return may be hotter than you or "IT" thinks.
    Just a thought.
    Brian @ Foggy Notion Heating :O)
  • Sam_11
    thanks I will insulate them, however the same setup for the baseboard gives me a 10-15 delta
