Counterflow problems
Alan(CaliforniaRadiant)Forbes
Member Posts: 1,243
By counterflow, do you mean 1-pipe steam, that is steam and condensate in the same pipe?
What kind of problems are you having?
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=53&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
COUNTER FLOW PROBLEMS
We came across a small house w/two 2" counterflow steam mains going to opposite ends of the building. Should I twin up the mains and treat it as one single? Or what?0 -
counterflow
If it's a true counterflow system and its working, don't mess with it. Otherwise you'll inherit it forever. More specifics on the reason for your being there will help us help you better.
We are replacing an existing 2 y.o. boiler that was unattended and dry fired. The system is true counter-flow. Steam and return thru the same pipe. The existing boiler was piped as if there were (was) a return. Also, there is a steam rad above the water level of the boiler in the basement where the boiler is located. The rad has a separate return and piped as a wet return into a hartford loop. That rad is the last connection on one of the two mains of which both are counter-flow. [Go back to my origional question]0 -
Frank , do you have any pics ?
Last year we replaced a boiler with 2 counterflow mains . We piped each main separately to the boiler , with separate returns . We dropped down into each main from the boiler header . Found some pics of the job . Hard to see some of the main pipes though .0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 916 Plumbing
- 6K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
