No heat
Chad_4
Member Posts: 1
have gas to the actual gas valve on furnace but something is not letting the gas valve open when the ignitor glows... pressure switch off blower motor is working??????? 32 degrees and dropping! status light on control panel is indicating everything is fine... gas valve is turned to on also.....
check voltage.
The next step would be to find out if the module is sending 24volt's to the gas valve. If it is and the valve is not opening it may have failed. Only option if that is the case is to replace the gas valve. If 24volt's is not going to the gas valve it could be the module is not sensing enough resistance from the ignitor or the module itself has failed. Time to call a pro to look at it. If your lucky they may have a universal part to get you up and running...0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 916 Plumbing
- 6K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
