poor man's curvo
Just wondering if anyone has tried a hand powered electrical conduit bender to bend 3/4" and 1" copper. I came across a bender and almost bought it but I figured I'd better get some feedback first on the pro's and cons.
Terry
  • tom_49
    tom_49 Member Posts: 269
    Terry,
    I'm not 100% sure , but I dont the sizes are the exact same. it probably will kink.
  • hr
    hr Member Posts: 6,106
    Wrong O.D.
    EMT condiut doesn't match copper tube OD.
    Plus, to bend hard drawn copper you need a two piece bender with the center ring and a follower. They need to fit the pipe very tightly to prevent kinking.
    hot rod
  • Tony Conner
    Tony Conner Member Posts: 549
    Poor Man's Curvo
    You can use manual tube benders, like Ridgid's 378 for 7/8" tube (which is 3/4" copper pipe) and 358 for 5/8" tube (which is 1/2" copper pipe). They're expensive new, but they roll through ebay every once in a while, and you can often pick them up there, for not too much money. They're ratchet benders, so they've got a lot of leverage - they're actually made for bending rigid steel or stainless steel tubing. Not a lot of effort involved, but the trade off is a little more time to make the bend. Compared to the time to get the measurements, and set up for the bend, it won't add much, though.
  • Al Corelli
    Al Corelli Member Posts: 454
    Just tried to use a 1/2" EMT bender to temp in a manual feed for a steamer last week. Was in such a rush, I used it on a lIVE water line. I got lucky, it didn't break, but it sure did kink the heck out of it.
    Hey, I got them heat that night. That's all that counts.
