diaphragm-type low pressure gauge
Michael Lemley
Member Posts: 2
That gauge is only rated to 140 degrees F and cannot handle the steam. I talked to technical support at www.gaugestore.com. The rep. I talked to said even with a siphon to isolate the gauge from the steam - there's water involved, which this gauge cannot handle.
I believe that I need a low pressure gauge that's protected from the steam/water by a diaphragm.
I'm trying to locate a low pressure gauge for my steam boiler. Hopefully something that measures 0-2 psi. I'm not having much luck finding a low pressure gauge that can work with steam. Any help would be greatly appreciated.0 -
gauges
Micheal: Try this
www.flw.com/ashcroft they have one 0-3psi
hope this helps.0 -
source of information
this is the source of my information regarding the gauge: http://forums.invision.net/Thread.cfm?CFApp=2&&Message_ID=129122&_#Message129122
mark sch0 -
I'm also very interested in this subject, since I just bought the Wika low pressure gauge. My question would be, what medium does the gauge actually see? I know there is water in the siphon, but there is air above that. As the system pressurizes, wouldn't the water compress the air above it and that's what would be acting on the diaphragm????? If so, this gauge might be more thatn adequate. The alternative type gage mentioned runs about $285.0 -
Anyone have experience with this low pressure gauge? If so, did it continue to work over the long haul? Sure hope there is a low cost, reliable gauge for all of us who need a low pressure gauge for steam boilers. I've had one of the Wika brand gauges for a week now. Will see how if it lasts.0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 917 Plumbing
- 6K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
