Radiator Replacements
Tom C
Tom C Member Posts: 2
I was thinking of changing the old fashioned cast iron radiators for a cast iron baseboards system. I have a natural gas fired boiler to generate steam heat, and it is working nicely. I sort of dislike the radiators I have, and may be happier with baseboard (off the steam heat)
Does anyone know what type of project that would be? Is this costly?
  • bob young
    bob young Member Posts: 2,177
    reconsider
    the new cast iron would have to be sized properly and installed with a return. probably more work & expense than its worth. consider recessed cast iron convectors if you so dislike free standing radiators. in case you don't know it , they are coming into vogue again and BIG TIME. your call.
