natural convection
jacsul
jacsul Member Posts: 4
Question??? I built a superinsulated house with a simple radiant heating system. Here's my problem, at +30 deg. my house overheats do to convection of water heater. Water temp. is at 90deg. Will a zone valve hinder pump circulation.
  • Empire_2
    Empire_2 Member Posts: 2,340
    2
    You shoulld have 2 zones. One for the water tank and 1 for the house. Zone valves are good, but you have to zone both. If using 2 pumps, you will need flo-checks on both lines. I think you are getting flow thru your house zone when water tank calls.
  • jacsul
    System is stand alone, I run a seperate water heater for DHW, I'm not crazy about open systems. Is there some way of stopping the convection flow other than a zone valve,and will it restrict the circulation, thanks in advance.
