Requirements for Electric Baseboard Heating
Kevin Adams
Member Posts: 5
Hi all, my questions, are there any special requirements for installing 220 volt Electric Baseboard Heaters such as does the walls need to be of a specific material? Should I RUN 3/4 INCH CONDUIT or 1/2 inch? Do they need to be sat at a certain height from the floor or from the corner walls? How about wall outlets how high should they be placed above the heaters? Can more than one heater be controlled by the T-stat and should the T-stats be mounted at a certain height and in a certain area? Can anyone help me? Thanks in advance Kevin.
kevin
After reading your posting, and not wishing to offend let suggest you consider employing a local licensed electrician. Best Wishes J.Lockard0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 917 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
