Viessmann Strap on pipe sensor won't fit
GW
Member Posts: 4,788
I have a job where I just barely squezed in the 9-spot manifold, circ, mix valve, ball valves in its tight little spot.
Anyway, can I modify the rather large strap on sensor? It certainly will not fit (did this thing grow over the last few months?). I'm kinda sure I only need to get the thermistor (is that the correct term?) properly reading the temp in the supply some how some way.
Thanks for any input!
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=368&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
- 86K THE MAIN WALL
- 52 Biomass
- 420 Carbon Monoxide Awareness
- 80 Chimneys & Flues
- 5.3K Gas Heating
- 95 Geothermal
- 154 Indoor-Air Quality
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 888 Plumbing
- 5.9K Radiant Heating
- 378 Solar
- 14.7K Strictly Steam
- 52 Water Quality
- 41 Industry Classes
