Pumps water toward boiler
Steve_141
Member Posts: 5
I have a system built in 1956, we get a lot of noise in the rear bedroom zone(close to the boiler). Bleeding the system works for a while but always comes back. The boiler outflow goes to two different zones, each having 6 lines that then go to a manifold which then goes to a pump by the boiler. Since the expansion tank and bleeder are on the out flow side of the boiler, shouldn't the pumps be after them?
Steve
Steve
Yes,
it would work better if the circulator was puming away from the compression tank.Retired and loving it.0 -
Change locations?
Do you think I can just reverse them where they are now? They about 2' away from the bottom of the boiler and this would have the water flowing toward the manifold.
Thank you,
Steve0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 916 Plumbing
- 6K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
