burnham oil boiler
jeff_25
Member Posts: 110
i worked on a BC/1 boiler today it been a while sence i worked on a steel boiler this one did not have any turbolator in it and i was wander if there needed the burner has a .75 h 60 deg nozzle on wayne burner i think my friend said it burned lot of fuel and the stack temp was way up there i did close down the air for better flame because it was burning hard i know it needs the comb test done on it the stack temp is a lot better we brushed the tubes new nozzle thank jeff
I am glad I got to the end of that post before I passed out from not breathing. Man, you've got to use punctuation.
sorry...
I assume you mean baffles in the tubes. Yes, they should be in there. It makes a big difference. And yes, you need to do a proper combustion test and adjust the unit properly.0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 917 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
