No Heat today
GW
GW Member Posts: 4,822
if it does nothing, not even break the air waves in the teeniest way, i bet there's an electrical issue, like no power or a transformer. You may need to become an instant service technician or get the phone book out.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=368&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Gary Wilson
Wilson Services, Inc
Northampton, MA
gary@wilsonph.com
  • Sherman
    Sherman Member Posts: 3
    Just came home from work and came in the house and it is 60 degrees in here. I checked the boiler to make sure the water level was OK, check the thermosatat to make sure it was set properly, and I replaced the batteries. I also turned off the heating system like the manual stated and let the gas clear out and then turn it back on. No use the furnace will not kick on. What other trouble shooting steps should I take before I call in a professional.
  • Empire_2
    Empire_2 Member Posts: 2,340
    Sherman
    Is the boiler a standing pilot type or spark ignition?
    Mike T.
  • kevin coppinger_4
    kevin coppinger_4 Member Posts: 2,124
    need more info...
    gas, oil,water, steam, fha....electronic ignition, pilot....
  • Sherman
    It has a spark ignition and it is a steam boiler, it also it gas powered.
  • Mitch_6
    Mitch_6 Member Posts: 549
    still any number of stuff
    does it try to light.
    does it just sit and do nothing
    does it have a motorized vent damper
    is gas in the rest of the house working
    does it start to light and then go off
    could be clogged pig tail to pressure switch, lwc sticking
    bad sensor, bad board, bad ignitor, bad motorised vent damper, bad t stat, spill or vent hood switch tripped, fuse blown, bad gas valve etc.
    Mitch S.
  • Sherman
    does it try to light. - NO
    does it just sit and do nothing - It does nothing
    does it have a motorized vent damper - it does not
    is gas in the rest of the house working - there is gas
    does it start to light and then go off - it does nothing
    could be clogged pig tail to pressure switch, lwc sticking bad sensor, bad board, bad ignitor, bad motorised vent damper, bad t stat, spill or vent hood switch tripped, fuse blown, bad gas valve etc.
