Buderus AM10
Nick_25
Member Posts: 1
On the AM10 the second Menu item is the flow temperature setpoint. My question is what does it do, and what should i set it at? I am using the GB with rad panels, some radiant, and a hot watermaker.
I'll try checking in my literature!
AM-10
The design temp should match the heat loss that the panel rads can handle. The other setting is the min temp that the the system can run at. RE: 14F odt 150F for system min temp 115F. The idhwh is not influenced by the AM-10 it is over ridden.
Ray M
Comfort Tech Corp0 -
Thanks Ray, you are correct. Default display is outdoor temperature, push "Mode" button once and when there is a call for heat, the value displayed is what the target temperature is - default value "32", "Mode" button pushed again is the reference temperature at 14 degrees, push "mode" button - minimum temperature of the heating curve, push "Mode" button - warm weather shut down. The AM10 will not maintain temperature in the boiler or system if there is no call for heat. Please contact us if there are any questions.0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 64 Pipe Deterioration
- 917 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
