heat loss/gain computer programs (which are the best ?)
rmb
Member Posts: 1
I see a lot of computer heat loss / gain programs and i wondering which are the better ones? Are they simple or user friendly? and how much do they cost?
programs
I have used Elite software and others,I now used hvac-calc
very easy to used and price right.But it will not do audits
Other then that worth the money.Check it out at
WWW.hvaccomputer.com down load and give it a try.0 -
Don't read this message. There's nothing there...
I told you not to go there!
Sorry, can't get rid of a double post ;-)
ME0 -
I like...
the FREE ones. They make the most cents!! (pun intended...)
We tested a whole bunch of them once from different sources against the same floor plan, and they all came real close to each other. Less than 2% difference as I remember. It's basic mathematics. Infiltration is really the only variable, and they all treated that fairly judiciously.
The major tubing manufacturers also offer their own versions of programs if you indulge in their tube.
I like Wirsbos program.
My designer/estimator likes the Kitec program, which runs on Exel.
There are some out there that will actually figure out how much of what lengths of rolls you need and manifolds and blah blah blah...
Trust your instincts. They're natural.
Heres a Google Search of free heat loss programs. http://www.google.com/search?hl=en&ie=UTF-8&oe=UTF-8&q=free+heat+loss+programs&btnG=Google+Search
Enjoy, and learn!
ME
here in ......
RI the state has a rebate program for replacement boilers.You have to do a total heat-loss of the home,BUT it Must be based on the ACCA J manual.Nothing else is accepted, not Wirsbo,Slant/Finn not even IBR calulations can be used.So if its something you maybe going to use for any like that buy one thats qualified.Try the link attached. Good luck Dave0 -
here in ......
RI the state has a rebate program for replacement boilers.You have to do a total heat-loss of the home,BUT it Must be based on the ACCA J manual.Nothing else is accepted, not Wirsbo,Slant/Finn not even IBR calulations can be used.So if its something you maybe going to use for any like that buy one thats qualified.Try the link .
Good luck Dave http://www.firedragonent.com/publications.htm0 -
Sorry
Try HVAC-Calc.com,Mr Eatherton how did you get my picture?
That was Good.0
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
