Caleffi Boiler Mix Valve.
Harvey Ramer
Member Posts: 2,239
How long does it take to respond with 180 degree boiler water?
Harvey
Harvey
Never Mind.
The response time increased exponentially once I connected the neutral wire on the boiler circulator! Daggone it!!
Don't tell me you haven't done something like that! I'll know you are full of mud and your nose will grow an inch longer!
Cheers!
Harvey0 -
Never done that, but...
I once installed a circulator backwards, pumping against a check valve, with the brain surgeon homeowner (seriously) and my ex partner looking over my shoulder….
And come to think of it, I MIGHT have mis-wired a pump or two :-)
It happens to everyone Harv.
METhere was an error rendering this rich post.
Those little things like that.
That's what keeps us humble!
Harvey0 -
Always
It just always seems to happen with the customers who are standing over your shoulder. I think it breaks concentration
Rob0 -
I have had
The cover screw on a Taco pump short the hot wire when buttoning it up. Nothing drives you crazier when you know it's right but something is wrong.....0
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
