The new Honeywell control system
mjmtech1988
Member Posts: 2
I want to know if the new Honeywell control system that Dan holohan mentioned would be any good with a single zone fin tube baseboard house?
The higher the B T U s the more efficient the heat output!!!
Ecobee
Check Ecobee or the Honeywell Prestige..I think it may be a better interface vs. switching to a TRV.0 -
Thank you for your replyThe higher the B T U s the more efficient the heat output!!!0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
