Will expansion and contraction cycles of a radiator mar the tile the radiator sits on?
George_in_Baltimore
Member Posts: 1
Hello all;
I'm the proud and protective owner of a recently renovated bathroom . The bathroom is warmed by a 16-inch radiator, connected to a single pipe steam system. The radiator sits directly on a new ceramic tile floor. We chose tiles with a texture to lessen the risk of falls.
So, my concern is whether I should shod the 2 radiator radiator feet opposite the feed pipe with furniture glides to protect the tiles from the expansion and contraction cycles of normal heating. Over time, won't the movement of the metal feet against the brittle ceramic surface act like a file and dig down into the tiles?
Is there a product more appropriate to the hot metal feet of radiators than plastic furniture glides? I imagine that some sort of radiator 'shoes' on the vent-side radiator feet would be beneficial is tipping the radiator back towards the feed pipe and helping the condensate to return to the boiler. But the shoes should deal with the heat and weight of the radiator over years of service.
Thank you for your advice,
George
George
Really shouldn't be a problem,
but...
Wouldn't hurt anything, either -- and might make it quieter. However, assuming that the radiator is already pitched well, I personally think it would be better (although it sounds a little back woods!) to use small squares cut from a plastic milk carton under the feet. They slide easily -- we often recommend them to reduce or eliminate expansion noises in piping and radiators -- and they won't rust. Besides, they're cheap...
Oh yes -- and they will take the heat, no problem.Br. Jamie, osb
We use them
all the time. Never had a problem.All Steamed Up, Inc.
Consulting0
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
