Gateway + Aerco + Caleffi = nice job.
JohnNY
Member Posts: 3,230
Here's a nice job in progress.
Go ahead, haters.
Go ahead, haters.
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes
Classes
No Pictures
The pic did not come through."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
I got the pictures
Good looking stuff. What's with the haters thing?0 -
The only thing I hate...
Is that I'll never get my solder joints to look that sweet. There's a YouTube video I'd love to see.
I actually misread the title and thought it said 'propress' instead of 'progress’
Top quality work, John.steve0 -
well
One of the ball valve levers are not level and those red pumps don't have the best wire to water transfer, John.0 -
Choking you pumps
I would make the recommendation to install the mixing device in the diverting position and not the mixing arraignment. The mixing setup creates a restriction on the inlet of the pump and is well known to disrupt the pump performance/ability to pass air.0 -
Specific?
Kevin,
Could you be more specific?
If the circ is moved outside the loop, there is no circulation through the loop when the valve is diverting. This won't work work in a heating loop. Maybe I am misunderstanding your meaning.
John,
Nice looking job. Do you have final pics?
Albert Einstein0 -
...0 -
No idea...
...what this means.Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Classes0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
